Hello everyone,
I've got a GP 2007 (56) 1.4 petrol and it won't start anymore.
It all started last year with the warning at the start 'Excessive radiator fluid temperature stop & turn engine off', anyway after searching on this forum I've decided to change the battery; all good until this year in January when it started all over again.
The battery was fully charged and the car was starting after couple of attempts (screeching noise from starter motor); sometimes it was starting straight away.
After a while, while driving around the engine was literally cutting off; luckily it 'bump started' itself.
Then I've changed the MAP sensor and the thermostat; no change whatsoever :bang::bang:; tried at least to get rid off the radiator warning.
The symptoms now are when trying to start the car:
-no noise coming from fuel pump
-immobiliser symbol on dash (car with lock)
-EBD failure (message on dash)
-ABS symbol on dash (ABS unavailable)
-Power steering symbol on dash (have power steering checked)
-the voltage stays 12.72v when turning the key
-the lights, radio, horn, wipers they all working
-obd2 reader can't connect to ECU
I've checked all the earthing points (using engine-bay-earthing-points thread), plus the one hidden under the air box; brush them all not as they needed.
Tried to start the car with spare key.
Next thing I've used jump leads to bypass the earth strap to the engine and between the engine and the chassis (using electrical-gremlin-thread).
Then measured the voltage from positive to different ground points; voltage was the same on all points; also all the fuses are fine.
Lastly I've removed the fusebox to have a closer look; no sign of any water..
Any other ideas ?
Any other ideas ?
