RobinPanda
Hi, I’ve had a loud bearing noise recently from my 2013 4x4 0.9 twinair Panda. 108k miles. It occurs when in gear, out of gear, forward or reverse, clutch in or out…I’ve removed the gearbox and inspected and there is a fair amount of side to side movement in the output shafts to the front wheels, the rear output and input shafts seem pretty good. It’s been suggested it the differential carrier bearings. Any thoughts?
So I’m looking at getting it rebuilt, but wondered if anyone could recommend a Gearbox engineering company to do it.
Also should I replace the front drive shafts if there is play?
The rear differential seems to have a fair amount of lash, is this normal? Maybe 10 degrees of motion before it turns the wheels?
Lastly the clutch was renewed by the previous owner who put in a solid flywheel…wondered if I should put back the Dusl mass version, or stick with it as is?
- Model
- 2013 panda twinair 0.9 4x4
- Year
- 2013
- Mileage
- 108000
