- Joined
- Sep 14, 2009
- Messages
- 19,899
- Points
- 3,414
Presumably Fiat wanted the 100HP to have a more precise feel in the steering and the wider tyres will increase side forces. But the diesels have heavy engines with much better mid range power so I cant see them giving the suspension an easy time.
The RHS bush on my car was knackered with grey aluminium dust showing. The left looked OK. Handling was affected by white lines but not terribly.
I suspect front arms of either type from a good brand (Original Birth or Magneti Marelli) will do just fine on the 100HP. Avoid the no name stuff even if it's cheap.
The "standard" track control arm OEM part number is 50703129. The Original Birth is £37.80 inc VAT from Shop 4 Parts. The 100HP type bushes will add another £10 so we are already close to £50 each side and still have to press out the "standard" bush and hope the 100HP type will fit.
The 100HP track control arm is OEM 51857135. Magneti Marelli cost £77.76 each from S4P and it will fit straight on. Other suppliers ask a similar price.
If you do not have access to a hydraulic press the options are -
(a) Spend £160 per pair and be done with it.
(b) Fit "standard" arms and save £80 but risk them being too flexible. I suspect they'll be fine.
IMO the cost saving and additional hassle of trying to swap the rear bushes is not worth the bother. But the considerable cost saving of "standard" over 100HP is maybe worth the gamble.
