- Joined
- Jan 5, 2019
- Messages
- 353
- Points
- 159
Had a totally flat battery recently. Not sure if my wife left the ignition on when she parked the car in the garage, but the battery was massively discharged after only a few hrs. I first thought it was some sort of electronics hiccup due to the weird light show on the display, and tried disconnecting the battery to reset everything, but no change. Then I measured voltage and found around 8V! My intelligent charger refused to charge this, so I had to use a classic dumb charger that managed to deliver around 8 amps but showing signs of stress. After a while, the battery came back enough to start the car. The generator pumped up to 70 amps into the battery at revs, so I decided to charge overnight with the intelligent charger which now accepted the battery. Next day all was back to normal with a voltage around 12.8V.
The battery is around 4 years old and probably experienced some reduction in lifetime from this exercise, but so far all is working fine. Will see how it copes in winter. It is a S/S battery btw.
