Coupe  Fiat Coupe LE - Build Thread!
Hello all!
New project, black Fiat Coupe 20V Turbo LE.
Done around 88k, brought from JBT at Midlands car servicing, been off the road since 2012.
My main focus when looking for a LE was rust as once you start welding you never seem to stop.
Thankfully this is in really good shape, it was quite heavily modified at some point to over 400bhp.
JBT built the engine with forged rods/pistons and a Garrett GT3071 so it should be fairly potent!
Plan is to recommision the car so i can use it daily and also correct a few of the mods to make it more reliable and cleaner.
I want the car to be as if it was made this way from Fiat.
So, pictures! Not too many of when it arrived, certainly covered in dust..
Pre delivery:
All fairly complete, just needs some work.
Now in my workshop
Pre strip down to discover whats undernearth.
Some water injecton kit with a lot of extra wiring... all to go
Lots of silicon and clamps...
3" exhaust all the way through but it was hanging off, all the mounts were broken, it was rubbing in places and had no cat.
Lots of pipe joiners and jubilee clips!
AC has seen better days!
Lot's of cracked pipes
Lots of stuff like this, hoses just capped off...
Found the air temp sensor just floating in the engine bay! Not in the inlet manifold?
First thing to go was the water injection, wiring was just twisted onto the injector wiring.
Stripped out
Wiring repaired and heat shrunk
New boot and thats one job done
Started stripping down to see what else i would find
AC Rad out, well rotten! AC is being deleted, never use it and removes some complexity.
52057923647_21c9c9f517_c.jpgIMG_1015
Oil feed line to the turbo was not ideal, really sharp bend onto the fitting.
52059447225_d4474381cb_c.jpgIMG_1016
52058961756_231fa6d3f0_c.jpgIMG_1019
52058961736_69d27a09ab_c.jpgIMG_1024
Made up a new AN4 PTFE fitting, along with heat protection
52059198819_34fb4471a2_c.jpgIMG_1081
52059198769_78d5afff67_c.jpgIMG_1082
As i was doing the turbo line i noticed the undertray was missing and also the bottom rad support was rotten and bent...
52058995018_9898b8d40b_c.jpgIMG_1084
52058995013_ab7130c4f1_c.jpgIMG_1086
Yummy!
52058961661_b2f0ec9d08_c.jpgIMG_1087
The original FMIC was ok, but needed the front bumper cut, the undertray wouldn't fit and it was rubbing.
So i came up with a plan, i wanted the original undertray on, i didn't want to cut the bumper. So i decided to move the radiator over 30mm and redesign the front end.
This is how it ended up, i used a new FMIC with all custom pipe work, i tilted the FMIC 30 degrees to get it to fit.
52058994998_0c3a76a9f6_c.jpgIMG_1110
New mounts welded to the removable front panel
52059447075_8acd9c4862_b.jpgIMG_1111
Pie cut and welded, this wraps around the radiator:
52058961631_e4972c9400_b.jpgIMG_1112
52059447040_dabdd2af98_c.jpgIMG_1113
Very tight but 15-20mm of clearance all around
52059198679_4c3e4233d6_c.jpgIMG_1117
Here you can see the intercooler pipe now sits inside the undertray out of harms way
Second boost pipe made to connect the intercooler to the manifold
52059447030_19a25374ea_c.jpgIMG_1114
52059198694_47a1fddb79_c.jpgIMG_1115
Wanted to use the original airbox as previous testing has shown the airfilter is unlikely to cause any restrictions
52058994918_e213dc6ec8_c.jpgIMG_1116
Next up was oil drain for the turbo, someone had used some kind of chemical metal to hold it in place but it was leaking.
52058994903_84d35d77f2_c.jpgIMG_1118
52059446970_df1da52af7_c.jpgIMG_1120
52057923367_fe5ba7a000_c.jpgIMG_1122
Stripped down the front of the engine so i could give it a clean and also fit the non AC mount
52058994883_f4eb6a3d72_b.jpgIMG_1121
AC and Non AC
52058961541_ce29f295c7_c.jpgIMG_1208
Mount removed and block cleaned
52058994853_c901134a4e_b.jpgIMG_1210
New mount on
52057923337_5ed1c16fab_b.jpgIMG_1214
Change the PS bearing as both were worn
52059446885_abf7b0a971_c.jpgIMG_1211
52062339261_9fa616ea82_c.jpgIMG_1600
Fitted
52062339241_20426164d3_c.jpgIMG_1601
Next was to sort the maniold as it was cracked
52058994818_2e717779d7_c.jpgIMG_1215
Can just see them here
52058994803_f4e4ac11f0_c.jpgIMG_1216
Ground out
52057923282_b26f815d34_c.jpgIMG_1218
TIG welded up
52059446840_52f9a9510f_c.jpgIMG_1219
Next i wanted to sort the manifold bolts, these had been done up too far and had pushed into the oil passages, so stripped cleaned, new studs and threadlock to stop them weeping.
52059446825_f743edf06d_b.jpgIMG_1222
52058961436_4f7fb3517b_c.jpgIMG_1224
All studs replaced
52059446780_9889947bba_b.jpgIMG_1225
Next i wanted to sort the wheel arches, the brake pad sensor wires were cut off and there was cable ties everywhere.
52058961391_0d2c71ca51_b.jpgIMG_1227
After with all the wiring back in place along with all the correct clips
52058994128_5a6864a4b2_b.jpgIMG_1273
Pass side
52059446455_62c79af913_c.jpgIMG_1247
52058994213_74cf13fd81_b.jpgIMG_1253
52059197944_5f3d94a8a4_b.jpgIMG_1270
Re-routed the shock canisters into the engine bay
52058960931_158066bed3_c.jpgIMG_1249
52058992148_c04e0ebe19_c.jpgIMG_1533
52057920932_013cf1e47c_c.jpgIMG_1534
Some good news though, very clean! Zero rust!
52058994258_bb6bf5f269_c.jpgIMG_1250
52058960916_37e31c35fe_c.jpgIMG_1251
The drivers side front tower was rusty so changed that.
52058961351_1191b10ea0_c.jpgIMG_1229
Was some rust behind the tower so drilled that out also so i could treat and re-weld
52059198404_7f5e3684bc_c.jpgIMG_1231
52058994603_3fc9c7f4fd_h.jpgIMG_1233
U-POL zinc primer on first
52057923077_0d5dc8d3c2_c.jpgIMG_1234
Back side also
52059446625_fea7373e66_c.jpgIMG_1235
Re-welded
52058994513_f08c066eac_c.jpgIMG_1236
Old and new
52058994493_d034360b1d_b.jpgIMG_1237
52058961121_382685ca87_b.jpgIMG_1238
52058961106_0b7f6c7cba_c.jpgIMG_1239
Gave the new tower and chassis leg a spray
52059198219_346eb9e3e0_c.jpgIMG_1240
One side done
52059198199_44040617d3_b.jpgIMG_1243
Pass tower was ok but the leg was scabby in places
52059198184_de35fb0a26_c.jpgIMG_1244
Primed
52059446510_9d8095c822_c.jpgIMG_1246
Painted and re-assembled along with all stainless hardware, gave the battery tray a paint also
52059197934_da57fbaf85_c.jpgIMG_1271
Also painted all the front side bumper supports and all the brackets
52058960796_da3707efb0_c.jpgIMG_1304
Fitted up with stainless fixings again
52059197909_099ba80986_c.jpgIMG_1305
52058960766_b5a1b71c9a_b.jpgIMG_1307
52057922737_70544f53e6_c.jpgIMG_1308
52059197879_da8f099815_b.jpgIMG_1309
Drivers side with new horn brackets
52058960736_4c0399468b_b.jpgIMG_1311
52057922692_15250a3d14_b.jpgIMG_1312
Nice simple job, bonnet, new handle and cable
52058994008_4a9ebafe3d_h.jpgIMG_1314
Fitted
52059197799_8e5808148e_b.jpgIMG_1315
Next was sorting the underside sills, rot free! But had been jacked up on them... Annoying!
52059198004_d9ebeaf994_c.jpgIMG_1265
Underseal removed and sill straigtend
52059197984_54cc21075f_b.jpgIMG_1266
Re-underselaed
52059446375_947c21c75d_c.jpgIMG_1269
Same on pass side
52058960391_0e98296627_c.jpgIMG_1336
Moving onto the rear now
Corrosion check, all looks good!
52058993878_bee392c0c0_c.jpgIMG_1318
52058960606_ccd7c72075_c.jpgIMG_1319
52059445955_400512710e_c.jpgIMG_1331
52057922387_3e347f7d6b_c.jpgIMG_1332
Stripping the rear arch liners off
52057922537_785c26ba00_c.jpgIMG_1321
Looks good!
52059446015_d71cb81f04_b.jpgIMG_1324
52057922437_7202381346_c.jpgIMG_1326
52058993628_c73b23c5a9_c.jpgIMG_1341
52057922252_42feeb6f2d_b.jpgIMG_1342
Boot floor
52058995218_18ce3b055c_c.jpgIMG_1383
Pass side tower is a bit scabby
52058960561_f8c1be889d_c.jpgIMG_1322
Drivers side has gone
52058960436_518a178c03_c.jpgIMG_1333
Cut off and new one welded in
52057922372_2f6468ee70_c.jpgIMG_1334
52059445885_9e31cc3697_c.jpgIMG_1337
Few little scabby bits where the underseal has lifted
52058993778_40d5561eeb_b.jpgIMG_1325
Boot floor edge, gave that a clean up and even found a pound!
52059445970_4697e8de37_b.jpgIMG_1327
52057922412_389ac8e977_b.jpgIMG_1329
Wanted to preserve the car so cavity waxed the life out of it.
52057922322_e22fdba4da_b.jpgIMG_1338
Rear end done
52058993658_7a87dcacd7_b.jpgIMG_1339
52058960341_3708e236f5_b.jpgIMG_1340
52059197509_b754483932_c.jpgIMG_1344
Rear jacking points still good!
52059197474_09a3be6cbb_b.jpgIMG_1346
Even clen inside! All now protected
52057922197_6a292edffb_b.jpgIMG_1347
52058993543_56737bdf9b_c.jpgIMG_1351
52059445735_5c408edc9d_b.jpgIMG_1352
52058960191_a68d0a7148_b.jpgIMG_1353
Can see in the pic here where i removed the hole plugs to cavity wax
52059197384_3927f37f3a_b.jpgIMG_1354
52058960136_362a516ba5_c.jpgIMG_1361
Boot floor still mint
52057922022_c09ab39746_b.jpgIMG_1364
52058993308_99884c2614_c.jpgIMG_1366
52059197124_cdfea6138f_c.jpgIMG_1367
Front end protected also
52058959901_969f4f05d6_b.jpgIMG_1368
52059197084_16c00423af_b.jpgIMG_1370
Cleaning up and refitting the arch liners
52058959861_c4c7693f80_c.jpgIMG_1371
Painted the bumper mounts
52058993163_5280d69636_c.jpgIMG_1372
Foam back on
52057921807_9b99689e37_b.jpgIMG_1374
Fitted
52059197034_168c65085a_b.jpgIMG_1375
52059445350_7abc423e50_c.jpgIMG_1377
Rear mud flaps fitted with plastic fittings rather than the rivets
52058993073_92f255b7e3_c.jpgIMG_1381
52058993098_7b89b5cfdf_c.jpgIMG_1379
52058959796_27a2fc0807_c.jpgIMG_1380
Silly thing but also got new clips for the rear lights as they were missing
52059445220_955cd5daf0_c.jpgIMG_1389
52058959701_a72fa4c471_c.jpgIMG_1390
Boot done!
52058992963_37625c2dc5_h.jpgIMG_1399
Next up was the heatshields and handbrake mount, heatshields were mangled and mount was rusty..
52058992868_b9516fae88_c.jpgIMG_1405
Second hand one which was cleaner
52058959591_83bdd3a0b3_c.jpgIMG_1406
Cleaned, painted and ready to go
52059445060_97ecbe8354_c.jpgIMG_1409
52057921547_06af64c6fd_c.jpgIMG_1411
Much better, with stainless fittings
52057921542_d819795c32_b.jpgIMG_1412
52058959551_fd834440de_b.jpgIMG_1413
52058992548_83e2501ec1_c.jpgIMG_1442
Rear shield was missing, new one fitted
52059196714_c839e78855_c.jpgIMG_1415
Tank straps removed, the rear bumper undertray was ziptied to it, as all the bolts had broken off
52058959501_79c730bc2f_c.jpgIMG_1418
Can see the snapped studs here
52058992753_cb90631fa7_c.jpgIMG_1419
Welded a nut to the broken bit and extracted
52058992738_cedb6458aa_c.jpgIMG_1421
Painted and ready to fit
52057921377_78c31a59e3_c.jpgIMG_1443
Fitted tank protection along with stainless fittings
52062361768_95857e2746_c.jpgIMG_1606
New fixings
52062361748_e59b8be018_c.jpgIMG_1607
Done
52062339126_99ff32e5d0_c.jpgIMG_1609
Next was the rear brakes, not gone too crazy as i will use the car daily.
52058992723_e21b041628_b.jpgIMG_1422
Stripped the whole lot off, this is so i can replace the bolts with stainless
52059444915_c00d60a06b_h.jpgIMG_1423
Repainted backing plates
52057921427_c122119386_c.jpgIMG_1424
ABS and brake line fitting bolts replaced with stainless
52059444805_52abe27e9f_c.jpgIMG_1425
New discs and pads fitted along with the cariers have a quick paint
52058959381_f25126e053_h.jpgIMG_1441
Drivers side
52059444675_2cdda00878_c.jpgIMG_1467
Done
52058992508_7603c9666e_c.jpgIMG_1466
First was the top mount as that was in bits
52059196344_3f2db41532_c.jpgIMG_1470
Inner removed
52059196339_7f5569b5bb_c.jpgIMG_1471
Well gone!
52059444620_248aaca761_c.jpgIMG_1472
New one fitted
52058958901_34617e91bc_c.jpgIMG_1532
Full service kit ready to go, cambelt, waterpump, aux belt, new pads, cam cover seals, exhaust manifold gasket
52059445090_ab46d6270c_c.jpgIMG_1407
52062574239_091b98cd3c_h.jpgIMG_15699
Timmed up and locking blocks on
52059196314_8d1430d217_c.jpgIMG_1475
Water pump removed
52057923687_872c3b5e59_c.jpgIMG_1474
New pump, tensioner and bearing
52059198914_0bf974308b_c.jpgIMG_1476
New belt on, re-tourqing the camshaft caps
52057921287_32c5c443d1_c.jpgIMG_1477
Cover re-fitted with stainless fixings
52059196274_d4bed28d51_c.jpgIMG_1478
52059196254_7e7f2fc112_c.jpgIMG_1479
Getting ready to re-fit everything now, non AC water pipe fitted
52058992403_2ff89dcd46_b.jpgIMG_1489
Manifold refitted with brass nuts on everything
52058959126_80f8e46b91_b.jpgIMG_1494
New oil filter on
52059444535_f7ccff1d63_c.jpgIMG_1496
New DS engine mount
52059444500_d54c0514e1_b.jpgIMG_1497
52058992268_5149c1768a_c.jpgIMG_1507
52057921162_3415ebd246_b.jpgIMG_1503
Oil cooler mount cleaned up and painted
52059196179_7b74be79d9_c.jpgIMG_1500
52057921172_38c4d51bbf_c.jpgIMG_1501
Both mount and oil cooler bracket fitted
52058992283_c7712875f5_b.jpgIMG_1504
Bit of a pointless one but fancied a new oil dipstick
52057920897_69963cdefe_c.jpgIMG_1535
Turned down in the lathe
52058992088_073ee346f7_c.jpgIMG_1536
New end welded on
52057920842_7733a653e0_c.jpgIMG_1537
And done, nice blingy aluminium one
52059444245_60677f6cc0_c.jpgIMG_1538
52058958801_9418aa484f_c.jpgIMG_1539
Also sorted my water pipe to header tank pipe work
52058992053_8a8341def2_b.jpgIMG_1540
AN12 fitting squared up
52059444195_39680fa7d5_c.jpgIMG_1541
Turbo had no support so made one up that mounts on the block and gearbox
52057920702_1688a5a506_c.jpgIMG_1551
Made a new oil drain on the lathe, this will slide into the hole in the sump
52058958696_ccb51db131_b.jpgIMG_1553
And new drain completed and fitted
52058958676_6a89b67f74_c.jpgIMG_1554
Next was sorting the 3" exhaust
Few issues with the existing, not mounted correctly, rubbers perished, rubbing the handbrake cables
Missing the mounts
52062829330_6e9da35fb1_b.jpgIMG_1569
52061299577_22c0b3136c_b.jpgIMG_1570
First up was to add some proper mounts to the downpipe
52062362058_7e830487f6_c.jpgIMG_1571
52061299477_a153965844_b.jpgIMG_1588
Made a V-Band drop in 400 cell Cat
52062829320_b25467d51a_c.jpgIMG_1572
Moding the downpipe
52062339461_938db5b0e1_c.jpgIMG_1573
52062829280_6cf68c2799_c.jpgIMG_1574
Cat mounted
52062574709_bdb8176858_b.jpgIMG_1592
New centre mounts made to support the mid section
52062829265_f2901150a4_c.jpgIMG_1585
52062339306_0bae636807_b.jpgIMG_1596
Another new mount to pickup the side mount
52062361973_8b34c3c0aa_c.jpgIMG_1586
52062829190_b24d57649c_b.jpgIMG_1595
Rear mount created as this was only using 1 peg
The original exhaust was at an odd angle
So re-made
All completed and fully supported
Oil cooler re-fitted along with a custom rubber support i made to steady the pipes
Also completed the bottom radiator support, this moves the rad over so i can get the boost pipe around it
Protection added to the chassis leg to protect the moved PS pipes
New Riv-nuts added to the subframe and towers
Trial fitting of the new undertray
More coming in the next few days!
Thanks all
