Did the compressor start? When the AC came on?
Typecastboy
Eh up, yup already got the new resistor in- no worries on that - just didn’t work the fan !
I didn’t register that the plug I removed from the resistor was the fan plug - am I understanding your post ? The resistor plug has a yellow and blue plug with two spade terminals in it. If this is the fan plug how do I tell which is positive and negative Terminals or does it not matter?
That will save me taking the fan out completely which was my plan on Saturday
If you can confirm I’m correct with above appreciate it.
If it works it rules our resistor and fan, then it’s replacing next cheapest parts like relays and temp sender on engine
Cheers for taking time to reply
Jackwhoo
Might have confused you in the write up, unless I’m misunderstanding
I followed the wires from the resistor back to a second multi plug down the fan cowl, if you followed the wire then further it went straight to the fan motor.
I unplugged this second multi plug and stuck the test wires in, these feed directly to the fan motor itself.
So I pretty sure that’s the same as your describing - correct me if I’m wrong.
Ok
Sounds like replacement fan required then.
Before fitting replacement fan it test it as you tested existing one.
I believe the fan in aircon models is usually uprated to cope with the high speed mode of the two speed system, however most 500s had aircon, so tracking one down should not be hard.
John 202020
Confused mate - the two wires that go into the fan motor went straight to the multi plug I uncoupled and then stuck my two test wires into and then these ends to the battery . If I take the fan off ( which I will do anyway tomorrow) I don’t know how else to test it again as the end I stuck the Multi plug into is the physical end of the fan motor feed? Hope I make sense.
Cheers for all the help so far
Keep it coming I need it .
John 202020
Typecast boy - that’s what I thought there were two fan types one aircon other without, no idea what difference is hence any part number advice. Seen a couple on eBay circa £46,00 which I think will fit.
Cheers again for all help
