OP OP 0 09andy500 New member Joined Jan 25, 2024 Messages 9 Points 1 Location Cambridge Feb 14, 2024 #21 John202020 said: Sure you didn't pull the engine cooling fan relay? Don't think, can't check at work, that the blower has a relay, but will have one to control the ac if fitted. Click to expand... Whoops, yep... climate control. Wrongly assumed that was for the blower, but air con
OP OP 0 09andy500 New member Joined Jan 25, 2024 Messages 9 Points 1 Location Cambridge Feb 14, 2024 #22 A3jeroen said: Isn't there a Maxifuse in the fusebox near the battery? gr J Click to expand... Do you mean inside the main fuse box... I know there are maxi fuses for the rad fans, but don't think there's a maxi for the blower motor
