vexorg
Prominent member
- Joined
- Aug 14, 2021
- Messages
- 1,832
- Points
- 564
A new one this weekend, my daughter saying her 500 was making a strange and bad sounding noise.
I'd have sworn the exhaust was touching the body, this loud resonating noise from under the handbrake area. But no, exhaust was miles away from the body at all points, even moving the tailpipe around.
Turns out that when the radiator fan goes on to high speed then that noise starts. You can barely hear it outside the car, and only a little in the engine bay.
Obviously hot day and aircon on all mean it's at high speed more often just now.
Bumper off to check what it was. So radiator itself felt a little loose in the top rubber mounts, not overly so just a bit easy to move back and forward. The fan mount on the gearbox side has a little movement in the clips, half a mm or so back and forth.
The fan itself feels secure, and no real movement or play in the bearing.
I packed out the radiator mounts to lock it in firmer to the rubber mounts, then forced a cable tie through the fan mount to rad body to stop any movement. That helped a little, but the noise is still noticeable.
The blades of the fan have weights on them, I'm wondering now if one has come off and it's lost balance. Either than it is the fan bearing and just cant feel it by hand.
It's done 50k miles in 8 years now, are the fans prone to failing (not read anything about that)
