I'd put them both new, especially having bought them both already.i bought the left too but with any luck that can go back.
Put drum on side you not adjusting.
Press pedal slightly to slightly push pistons out then turn adjuster nut (push top of nut toward back plate to reduce clearance) this makes it much easier to turn adjuster nut and so less likely to damage anything. Do this until drum drags slightly when pushing over shoes.
Then do
Other side.
Then take drums off and adjust cables to take out slack without move shoe levers off stops
I've now understood what you are saying but i'm reluctant to try, because i killed a cylinder like this a couple of years ago, then two more cylinders trying to replace that one.Put drum on side you not adjusting.
Then do
Other side.
No dont do thatFurther question; is it safe to put the handbrake on with the drums off? Would it be of any benefit?
The mystery of what has gone on here is solved!
The old handbrake cable is genuine Fiat Grande Punto! But...
The previous mechanic bought the left hand cable and put it on the right hand side!
The heatshield on the left is longer than on the right and got in the way of a bracket, so the guy took it off and put a home made one on.
According to the manufacturer the left is also shorter than the right by 2 cm, i measured 1cm the first time around but when i tried again i found the difference is 2cm.
There are 5 splits on the cable, where it has rusted, but the cable does still move freely, so that was a red herring.
In other words, all i need to do is to fit the new right handbrake cable without misshap and i'm done and dusted.
Fingers crossed.
They still can when under load after pulling on and that will reduce their braking effort too.There's an element of fingers crossed here. It might be the correct cable to fit, but i make a mistake somewhere, to be human is to err!
I was expecting the rusty cracks to have made the cable stick, but they didn't make a difference.
I've just tested this and the old cable is noticeable harder to move when rounded/curled. Especially in comparison to the new one.They still can when under load after pulling on and that will treduce their braking effort too.
Off the car in a straight line they may well feel free to move easily, so new is best.![]()
Yes. Old cables which have corroded or are maybe just "dry" inside with degradation of nylon liners etc, can appear to be free and working well when not under load - ie when off the vehicle or disconnected at both ends on the vehicle - but bind up significantly and reduce the force applied to the levers in the drums when actually operating the brake shoes. Sometimes this can be dramatically improved spraying something like WD40 liberally around (don't get it on the friction linings though) but this is never a permanent solution. Just might get you past an MOT if the cables are just a bit "iffy" thus giving you time to fit new cables at your leisure.I've just tested this and the old cable is noticeable harder to move when rounded/curled. Especially in comparison to the new one.![]()
The MOT re-test is on Monday, so i have 3 days left to get the new cable on. I imagine the other cable is in similar shape, but i daren't put it on in case there is a mishap and i don't make the deadline. Getting passed an MOT always feels like an ordealYes. Old cables which have corroded or are maybe just "dry" inside with degradation of nylon liners etc, can appear to be free and working well when not under load - ie when off the vehicle or disconnected at both ends on the vehicle - but bind up significantly and reduce the force applied to the levers in the drums when actually operating the brake shoes. Sometimes this can be dramatically improved spraying something like WD40 liberally around (don't get it on the friction linings though) but this is never a permanent solution. Just might get you past an MOT if the cables are just a bit "iffy" thus giving you time to fit new cables at your leisure.
It does feel strange. Waiting while they fiddle with your car. And you're expecting the conclusion...Getting passed an MOT always feels like an ordeal![]()
Sorry to be a bit of a pessimist but, if the other cable is in poor condition you may find that the handbrake balance figure is poor due to the new cable being able to apply more force to the lever whilst the old one is compromised by friction due to it's condition. The only way you'll really know is when they test it but you can try putting both back wheels up in the air, applying the handbrake until the wheel with the new cable is just able to be turned by hand and checking the one with the old cable. If you can turn the old one quite easily by hand then it's likely it'll fail I've found. Mind you I do tend to be a bit of a "glass half full" type of person. I find it avoids disappointment mostly.The MOT re-test is on Monday, so i have 3 days left to get the new cable on. I imagine the other cable is in similar shape, but i daren't put it on in case there is a mishap and i don't make the deadline. Getting passed an MOT always feels like an ordeal![]()
Aye, called "preventive maintenance" isn't it. I'm a firm believer. Tends to save you money in the long run too.It does feel strange. Waiting while they fiddle with your car. And you're expecting the conclusion...
But... always taking good care of the car and fixing things at their first signs of something wrong gets you through, easy.
Speaking as an ex MOT tester, you can see the stress of the owner building up as you start writing whilst under their vehicle.It does feel strange. Waiting while they fiddle with your car. And you're expecting the conclusion...
With good reason...Speaking as an ex MOT tester, you can see the stress of the owner building up as you start writing whilst under their vehicle.![]()
