Just doing a general check over and noticed if I lift up and down on the exhaust, the engine rocks enough for the starter to knock on the heater tube that is bolted to the floor.
Also I have a fair bit of play on the engine mount for up and down movement. Should this be adjusted with shims & by how much?
I did try the updated spring but it caused so much vibration through the body the wife wouldn't get in it.
This is a 126 650 engine with starter on the side. If I lower the engine using s block it will hit the pulley on the lower engine cover.
Any suggestions?
Any suggestions?
