- Joined
- Jun 3, 2016
- Messages
- 149
- Points
- 56
Still running my elenganza 1.2 05 plate. which suddenly didn't want to start straight away this morning after it had been stood for 4 hours which was quite scary as I had problems with the crank sensor a few years ago!
Car started so as it was low on fuel I filled it up with the 'good stuff' 97% and a dose of redex just in case it needed a bit of a clean out.
Now ive noticed if I rev the engine up (when warmed up) the engine goes to an almost stall with the rev counter dipping to around 500rpm before the engine corrects its self and goes back up to 800.
Question is,as its just started to go below freezing here and the tank was neigh on empty, could there be some condensation within the fuel tank causing this problem or is there something more specific going on?
As for the redex, the car does get a dose every now and then with no running issues.
