dawpooldad
- Joined
- Oct 25, 2010
- Messages
- 19
- Points
- 8
I wonder if any knowledgeable member can describe the correct procedure for disconnecting the ECU.
I have a problem with the engine momentarily stopping and the engine light coming on, then the engine restarting on over run and the engine going out and everything back to normal!
I'm sure that it has something to do with the ECU connection, so I'd like to check the contacts.
I've noticed that the battery earth connector has a quick release clamp, so does this mean that the battery should be disconnected beforehand?
Also, exactly how are the connectors removed.
If anyone can help I'd be grateful.
Best Rgds
Dawpooldad
Best Rgds
Dawpooldad
