Technical Ducato issues
Jux
Hi! I need help with my Fiat Ducato. The car is from 2007 with a 2.3 liter multijet 88 kw engine. The thing is, the car's engine dies out when you drive or play with the accelerator pedal on the spot. Sometime it lets you drive or play with the accelerator quite long time, usually it dies after few seconds. But once the engine is out and you restart the engine, the engine will immediately start up and run at idle as long as the fuel runs out. But once you touch the accelerator pedal again or try to drive, the same thing happens. Every time the car dies the engine light comes on. The diagnostic reads the error code P0089. I've changed fuel pressure regulator (twice), overpressure sensore, EGR valve, intake air temperature and overpressure sensore. What else can I do or maybe someone have had similar problem and can point the right place where to look.
