- Joined
- Sep 14, 2009
- Messages
- 19,910
- Points
- 3,957
Lots of folks assume the engine is correctly timed when they fit a new belt. It might be ok but how would you know?
This should help -
https://www.litensaftermarket.com/f...nspanner/en/Installation_Procedure_979778.pdf
Usually, the cam wheel is loosened during tensioning but the cam itself is locked and crank has to remain in position. The cam wheel is locked to the cam after the belt is tensioned.
Fiat's spring loaded timing belt tensioner might affect the detail but in essence it should be the same process.
This should help -
