Technical Cowl removal..
zippeyrude
I'm parting out an old panda and was going to salvage the power steering unit
I'm stuck at the stage of plastic cowl removal.
I've removed two small torx screws on the underside, with a further screw hole not affixed that was below the steering height adjuster.
Is there something else I need to do?
I've seen as 2012+ image with clips, wondering if this was the same?
Mine is a 2008 active.
Any tips appreciated!
There are clips on the side
I done a few ignition switches
As far as I remember I slid an old credit card or guitar pick in
I can't remember if it's the top half that needs to push in or the bottom
Have you undone the hidden bottom screw
