I haven't sorryAnyone any experience of these? Thanks
don't see the logic in fitting one with a plastic spigotPersonally I would go with S4P. They have never let me down and my 2007 100HP still has its plastic spigot thermostat from new.
I agree with you, I'd be going with a metal one if my car had that type of fitment (It doesn't as it's the older 60hp engine) However I support Dave in that I too like S4p and would have no hesitation buying most of their stuff.don't see the logic in fitting one with a plastic spigot
because its never failed for you doesn't mean they dont fail
internet is full of them failing especially on 500 but also Lupo and Vectra's
My point is more about costs. All metal sold for the 100HP are silly money. All metal for Fiat 1.4 are reasonable. I would like to know why the plastic spigot fails (lowest price of all). Plastic inlet manifolds do just fine and plastic plumbing has pretty much taken over from copper pipes.don't see the logic in fitting one with a plastic spigot
find it easier to search by part number there's shed loads under £30. This was the cheapest, I dont always use the cheapest, I look at the poor reviews and see if they are genuine, look if they are genuinely in the UK if I need the part urgently and so on.My point is more about costs. All metal sold for the 100HP are silly money. All metal for Fiat 1.4 are reasonable. I would like to know why the plastic spigot fails (lowest price of all). Plastic inlet manifolds do just fine and plastic plumbing has pretty much taken over from copper pipes.
Household plumbing dosent have 100c water flow or the vibrations and external heat you get in an engine bayMy point is more about costs. All metal sold for the 100HP are silly money. All metal for Fiat 1.4 are reasonable. I would like to know why the plastic spigot fails (lowest price of all). Plastic inlet manifolds do just fine and plastic plumbing has pretty much taken over from copper pipes.
The inlet manifold is plastic and that's bolted to the cylinder head. Temperature is not the issue. After all, what is the average kitchen kettle made from? Engines run at about 80 C same as domestic heating systems and well within limits for these plastics.Household plumbing dosent have 100c water flow or the vibrations and external heat you get in an engine bay
As you say Koalar. It always looks so simple when you read it up in your Haynes manual (or whatever) but when that stud/bolt snaps off, bracket breaks, or you find that tool you were intending to use doesn't quite fit in the space available, it can all turn into a bit of a nightmare very quickly. Particularly frustrating when you think "if I just unbolt that and move it to the side then I'll be able to get at it more easily" only to break something which actually has little to do with the part you are trying to access. Then you're sitting thinking to yourself "if only I'd left it alone and worked round it" Ah, the joys, the joys!Often these jobs don’t go according to plan
It’s going to depend what tools are available to you, and how much is left to grip onto.
Mole grips
Pipe wrench
Vice
Screw extractor
Side cutters
Worse comes to worse it could be pushed out from the other side
Would just need another hose clamp
it hard to remember back to what it was like when I first encountered such problemsAs you say Koalar. It always looks so simple when you read it up in your Haynes manual (or whatever) but when that stud/bolt snaps off, bracket breaks, or you find that tool you were intending to use doesn't quite fit in the space available, it can all turn into a bit of a nightmare very quickly. Particularly frustrating when you think "if I just unbolt that and move it to the side then I'll be able to get at it more easily" only to break something which actually has little to do with the part you are trying to access. Then you're sitting thinking to yourself "if only I'd left it alone and worked round it" Ah, the joys, the joys!
keep an eye on it, especially coolant levelsThe thermostat seems to have gone on successfully. Temperature gauge sitting as it should and heat coming through the heater. Will check for any leaks but fingers crossed all is good. Just one question though. It was noticeable that the temp had to get to full temp before any heat came through the heater. It wasn't the case with the original. Is it likely that different thermostats let coolant through at different temperatures? Thanks again for all the help on this.
