Hi. The coolant system on my Panda 100hp has sprung what appears to be a tiny leak. There is a small damp patch beneath the car where the drip drops off the engine. Some also runs through the foil/foam that surrounds the exhaust sensor cables and finally collect on the exhaust.
I can't spot the exact location of the leak but is it likely to be from where the coolant hose runs into the block near to where those sensor cables connect? There is some salt type stuff collected at the end of the hose.
Hoping its not a gasket leak but the oil is clear so no water appears to be getting in.
It's a little tricky to get to so potentially a garage job and the expense involved. What are anybodies thoughts on using one of the poured in leak fixers? I've heard mostly good and some bad about it.
Many thanks
Many thanks
