Technical Clutch problems
Randomman
GTI Till I die
Northampton
Well I think its on its way out.
There is a funny scratching whirr coming from the engine bay when I dip the clutch. Up until recently every gear was hard to get into when it was warm, that seems to have improved drastically all of a sudden, but the whirr is worrying me.
Any Ideas?
OP
OP
Randomman
Randomman
GTI Till I die
Northampton
arc said:
release bearing dead/dying ?
How would I check this? I hope its cheaper than a new clutch
Is there any sure way of telling if its a new clutch job?
arc
this is where i stand
Manchester
when u press the clutch, a fork pushes the realese bearing into the splines. if the bearing is knackered, it'll make a noise when u do that. it sounds like it is dying.
its a gearbox off job to fix, and you may as well replace the whole clutch whilst you're at it.
100hpJames
Has sport button disease
Nuneaton
Mine's the same unfortunately, after long journeys. When it's cold its quite difficult to change between 1st and 2nd
GeX
Lytham St.Annes
I think mine is on its last legs, or at least some part of the clutch is. I had the car parked on a hill the other day so it was in gear when i started it. The clutch was depressed of course but the car still tried to drive itself forward on the starter motor. It just kept rocking on the handbrake when i was turning the key.
Also i was swapping wheels over the other day, i had the car on but in neutral. As i was jacking it up and the wheel cleared the ground it started rotating, and at some pace too. I then had to get the wheel back on and lined up with a a moving hub. You could stop the hub spinning by holding it, still made an easy job all that more difficult.
arseofbox
Principality Retained :)
Midlands
Mine does that...I understand that its due to friction in the differential..I think :s...I'll investigate tomorrow and clarify, but its not unusual!
100hpJames
Nuneaton
did you not consider turning the engine off while its in the air? that way you can leave it in gear (only helps a little if your jacking the front though)
rallycinq
Autotest Special
Lake District....Moist
The internal friction in the gearbox will make the wheels turn, the fact that you could stop it with your hand meant it was not in gear at all.
OP
OP
Randomman
Randomman
GTI Till I die
Northampton
Either way, surely its a better idea to have your engine off when jacking it up?
Especially if you plan on going underneath
wolvescinq
Oh, the joys of FIAT ownership! I may well be looking at a clutch replacement job in the (hopefully distant) future myself. I'm getting a whirring noise that goes when the clutch pedal's depressed - garage says it's a worn clutch release bearing. Great! Gears are stiff from cold, but usually loosen up later.
Pep0
Established member
UK
I'd not drive too far from home. There is a guide, takes all weekend, needs trolly jack, axle stands and partner occasionally, best to replace the cable as well, experience is a hard school to learn in.
Noel
solpap
Harrow, Greater London
Mine is exactly the same at 54k miles.
Sol
Pep0
Established member
UK
Hi
Mine did 66k squeaked for a second like a mouse then went bang.
Don't forget to replace the clutch cable as well, while you have better access.
Noel
Drumsas
Glasgow
I have a problem with the clutch on a 1.1 sporting, the clutch peddle is pretty low to the floor and is making a creaking /cracking sound when depressed. I have tried adjusting the cable at the gearbox side but this hasn't helped.
The creaking sounds as if it's coming from inside the gearbox bellhousing, am I right to suspect a broken selector fork or missing pressure plate springs? or is there something more obvious that I could of missed.
