DBunX
Yesterday after a short drive from work to pick up my daughter I restarted the car to find that on all of the available settings for Climate Control there appeared to be a ticking noise, or what sounds like the noise created when you put a piece of paper on the spinning fan blades of a desk fan.
I assumed at first it was a leaf sucked up into the unit as I was parking, but when I switched to the front blow the ticking sound moved to an area around the steering column, and then back to within the air outlet at the base of the windscreen when on the demist setting.
I was a little worried, so turned it all off and drove home. Left it a few mins then went back out to the car and started it all up again, and put all of the fans on full to blow as much air through as possible. To my surprise the sound had gone, and on this mornings drive to work there was no sign of it.
The car is only 3-4 weeks old so the concern was that the Climate Control was a bit broken, however it does now seem fine.
Has anyone else had this before?
