Technical  clearing windscreen
dkwecoactive
oldham
The incessant rain of late has highlighted an issue. I really struggle to clear the windscreen. There IS air coming up through the vents. I can feel it. I have it on cold bringing in outside air but nothing seems to clear it, to the point of it being dangerous. I have searched the forums for similar issues but I'm a bit lost. Any pointers for an absolute novice?
Again important, Check the coolant level.
The heater will not work if the level is below half way
Test the heater are blowing toasty hot
I know it not on the windscreen but
If you set the controls as in the photo below
And the engine is hot, the centre vent should be blowing very hot if you put your finger in, not just warm, should also blow hot at idle
@dkwecoactive says
"It actually looks like the blower is blowing wet air onto the screen. The screen appears to get wetter"
I"d be more focused on why the Blowers aren't clearing the windscreen first
Either liquid has entered the ducts
Or
It's not blowing hot air on the windscreen
Low coolant, thermostat or blocked duck bills are the most likely
