Technical  Windscreen wiper arm reset
They don’t
They turn anti clockwise from rest looking from the bonnet
All this could easily be diagnosed if you post pictures and videos
The arms run diagonally should start bottom left and rise to top right as per photo in post 10
Would it not be a good idea to lift the arms up while testing if you having problems
They definitely did in the week. I didn't imagine it.
But gremlins eh?
I just now took the arms off, put tape flags on and they looked spot on, so I put the arms back on... perfect. So god only knows what I did different last time.
Thanks for all your suggestions though, I'll try to remember to test a problem in other, different ways in future.
Meio
Close the bonnet
Lift wipers off the screen they can't hit anything.
Switch on wipers
Do they park? Where do they park? Strange things happen when the linkage is broken. You can buy repair kits for about £20 search eBay.
Assuming it all moves normally. Allow the motor to park itself. Remove arms from axles and refit in the parked position.
If the motor does not park you need a replacement. There are no reliable ways to repair the internals.
