64,000 km 2014 model twinair 0.9 dualogic. Check transmission see dealer error yesterday. Car in limp mode. Won’t change into 4th, won’t go over 2000rom. I bought the MES licence and cleared a “clutch rpm” error in gearbox module. All now good and car “fixed”.
The issue occurred when I got a phone call just as I was about to set off, the engine had been warming up before that. After maybe 10 minutes a beeping started but I ignored it thinking it was a seat belt warning or similar. After maybe 20mins I set off but noticed the red cog warning light and check transmission and start/stop warning messages.
My theory is there MIGHT be some logic in the ecu along the lines of it is implausible to not see a clutch rpm for (say) 10mins in gear, so ecu logs an error.
After clearing the code I drove whilst monitoring the clutch using MES and the rpm only moves from zero when in gear and the car is moving.
Anyway fingers crossed the car has avoided the scrapyard.
