The wife's Panda is a 2014 1.3 MJ 4x4, and on a couple of occasions recently has been slightly problematic for her.
A week or so ago the dashboard went all christmas tree on her, and the car felt slightly hesitant. When she tried to turn it off the dash and radio turned off as normal, but there was a delay between turning the key and the engine stopping, perhaps a second or so. I had a look at the car in the eve, no stored codes, started and ran as normal.
The warning symbol has been on constantly, but I had attributed this to a faulty DRL plug and and bulb holder causing a check DRL message.
Problems today:
- The dash was all lit up again
- The external temperature display wasn't working
- The speedo needle was sitting at zero when driving
- Multiple messages were displayed.
- Have power steering checked, see handbook
- Check engine
- Check DRL
- Start/Stop unavailable
When turning off the first time there was a delay again, when arriving at home and trying to turn off it kept running, even with the key removed! So stalled it to turn off.
Did a code read via an app and OBD, get U1706 as the only code.
I'm not gonna get to look at it until Thursday AM. The first thing I'll look at is battery connections, voltage, earth cables incl earth points under tray.
What else should I be going for with the sort of symptoms described please?
Problems today:
- Check engine
- Check DRL
