Rayz Panda
Hi Fiat experts! First time poster but long-time lurking fiat owner of 3 years - most reliable car ever. Worked as normal without any issue before this problem came up
Yesterday I replaced the USB/AUX module socket in my 0.9L Fiat Panda (last one was fine but wanted to change the look as it was hanging out and missing a plastic part - replacement part attached/below). Unclipped the old part and swapped this one in, unfortunately didn't work as no audio and later only static. Checked fuses to see if anything tripped but all visibly fine and reseated them without issue.
After this, car wouldn't start. Ticking and some cranking sounds only. Observed dimming lights, slow window motors and 12v charge on battery using multimeter so assumed battery drained. Tried to jump start but no luck. Spent today charging the battery and swapped the AUX/USB module back and it started normally!!
Now though Panda is showing the common ESC, hill holder and 'check transmission' errors codes (this is an Ezy manual/duologic gearbox Panda - felt normal to drive today). I disconnected the negative battery terminal for 30 minutes to reset ECU, checked OBD and reset code (no codes found) but they are back when car in motion triggering on and off repeatedly. High beams on now doesn't work either, just turns off headlights + daytime lights.
I'm at a loss here what to do. Everything was normal before, I can only think it's something I've caused or triggered? Any ideas? Aiming to try mechanic shop when able to book in but Fiat experts in Sydney are rare... 93,000kms on odo
- Model
- Panda 0.9L twin turbo
- Year
- 2013
- Mileage
- 93000
