Went to Halfords to get mine done, the guy said no chance take to the dealer.
Arnold Clark / Fiat did it for free, no charge for builb either, although I was in getting front new brake pads checked.
Hmmmm.... maybe they changed the design on the 04 then. :chin:Found out that the plastic that surrounds the battery is clipped into the tray under battery and you can pull it out and squish it up.
Hello everyone,
Been reading the thread with interest as I have the passenger side front headlight bulb to replace and a rear fog light bulb to replace before the stilo has its MOT later this month.
I was wondering what the correct bulbs are that I need to get and if there are are any bulb kits available so that I've got a handy stash of them for future use
Any advice much appreciated!
Obviously depends on which headlamp your changing (main = H1, dipped = H7).I was wondering what the correct bulbs are that I need to get and if there are are any bulb kits available so that I've got a handy stash of them for future use
is it possible to replace a stilo 3 door stilo passenger headlight with a 5 door, are they the same dimensions and will it fit?
If you can take all the battery out then you can take the front bumper off. It really is that easy
Just remove and re-connect the headlamp connector first to see if that helps
Jon.
I recently changed the drivers side main beamwhich was a doddle. Then the passenger side one went and I naively thought it would be the same until i opened the bonnet.
I followed the battery removal approach and then got at the bulb with some difficulty and changed the main beam bulb. Hardest part was getting the weather cover back in. I thought I had done it.....
Put the battery back in to check, oh dear.... now i have lost indicator, dipped and full. Only one that works is the main beam!!!
I think i must have pulled out a wire somewhere along the lines of the power socket thing to the cluster or the bulbs but i have no idea with wires so am at a loss.
I think im going to resort to taking it to the dealer because I am put off by taking the bumper off....unless there is a bright spark on here that has another idea!?
Any suggestions welcome please!!
