Technical  Bushes
Technical  Bushes
Death
Someone's got to do it...
Nth Lincs
As I am replacing all four of my suspension arm bushes is Shop4Parts a good place to buy them from or is there a better deal to be had ?
Dont rule out your local dealer, dont fogret you have postage to pay from shop4parts and someimes there is only a matter of pence between the two
One of my local dealers was trying to tell me there are only two bushes on the rear suspension arm in total,so I wasn't to sure about him. His is price is £8.82 + vat per bush.
As said, only 2 per side, so thats ok.
If the factor price is that, seem a lot. Try shop4parts...remember we get 10%...check the forum.
Still after shipping i bet there is little in it.
A better option and not much more than you factor is HERE!!!!
I have used this seller, for both front and rear kits.
Great prices and hopefully never have to change them again.
Kristian
The prices seem to differ alot. From £32.40 for the rubber type to £60.88 for powerflex. I know the powerflex are better but my funds are very tight :( after buying the Cinq for traveling to my new job.
remember, unless you have a press (or access to one), you will also have to pay someone to fit the rubber ones, so the cost of £32 is not all you will pay.
EDIT: also, you may have to renew your rear brake lines at the same time as they often break when you remove the rear arms.
I can get to a press so that side of the job is not a problem,and hopefully my brake pipes won't be a problem as they look fairly new an have no corrosion on them. It's the bleed valves I'm more worried about but I intend to spray all bits with releasing fluid a few days befor I start.
