Technical  Bottom Ball Joints.
i used 293495150128 unfortunately there out of stock but a pound cheaper
pretty sure there were cheaper ones but this seller gave next day delivery which I needed because it was for a MOT
If you could replace the balljoints separately then you would be less likely to need the tracking doing afterwards.
When changing both arms you would normally need the tracking adjusting.
I've also found that some balljoints on cheaper arms last such a short amount of time that the rest of the arm is fine even when the balljoint starts knocking. It's a bit of roulette with cheap parts.
correct (y)
even expensive parts are a lottery. None seem to last the same as the originals. Even if they made by the same company.
its always hard to work out why sometimes impossible.
correct (y)
thats why i tend to opt for cheaper parts most of the time as im less annoyed if i have spent half the price and it fails :slayer:
