Bolt V screw
Bolt V screw
A bolt should not be driven by the head because it will twist and absorb some of the tightening torque, When that relaxes the bolt comes loose. A screw wont cope better, it just gets used for less heavy torques.
So a bolt threaded all the way up is weaker and less tortionally stiff than a part threaded bolt. For some reason its called a set screw. Logical? Not really. But if you think that's annoying try doing human anatomy.
ok then
this is a philips male driver
youve said my magic words a screw is threaded all the way up.
maybe anything with a strength stamp
I agree with what's been posted, a screw goes into a tapped hole or non tapped hole. Anything that has a nut on the end, is a bolt.
However, the exception is when a bolt holds something on, for example wheel bolts, they just go into a hole and are therefore screw-like, but the existence of the wheel before the medium that the bolt goes into makes it a bolt.
If that makes any sense at all :rolleyes:
but the bolts holding the wheel in place don't just go into a hole, they go into a series of pre-threaded holes which replaces the nuts. The alternative is a series of studs fixed to the plate so that the wheel is held on by nuts.
Helps if you use the correct screwdriver. :p
30-odd years ago we sold these individually or in sets and they were described as 'nut spinners'.
In prison a Screw is a guard and a Bolt is an escape - sometime referred to as a "Harry Holt" in Cockney Rhyming slang.
My head hurts reading this thread......
IMHO
a bolt is used when there is a pre defined hole with coresponding thread.
a screw is used where there is no predefined thread.
[ame="http://en.wikipedia.org/wiki/Archimedes%27_screw"]Archimedes' screw - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Question_book-new.svg" class="image"><img alt="Question book-new.svg" src="http://upload.wikimedia.org/wikipedia/en/thumb/9/99/Question_book-new.svg/50px-Question_book-new.svg.png"@@AMEPARAM@@en/thumb/9/99/Question_book-new.svg/50px-Question_book-new.svg.png[/ame]
