Okay, so in effort to test the stalk unit, I'll share the following:
Twist to activate rear = rear wiper on, standard speed, once every few seconds
THEN changing front speed = no difference, rear on at standard speed as above
Engage ANY front wiper speed + REVERSE gear = Rear wiper comes on continuously, fast. Regardless of
Regardless of the speed (slow/medium/fast) of the front wipers, that is how the rear one behaves.
What could this signify in regard to the STALK UNIT?
When I have the front wipers on and twist and turn on the rear wiper, it works one wipe for every two wipes of the front wiper at speeds one and two, so yes it speeds up with the front wipers. Can't comment on speed 3 as I never use it.
If the front wipers are in use and reverse is selected, the rear wiper comes on fast regardless of whether it is switched on or not.
How much doe the BC really do with managing the front wiper? I suspect apart from the intermittent and wash (double wipe) not very much. Why do I say that? Put the wipers on and there's a slight almost undetectable delay and they start. Makes sense as the BC does it's thing. Put them on flick wipe and they instantly fly across the screen. Even the slightest flick of the switch and they jump into action.
I suspect there is little and maybe no processing between the stalk switch and relay that drives the wiper motor. If I'm right (and it is a guesstimate) your problem may be just the BC relay.
Fit the new stalk then listen for that relay clicking. Even better work out which stalk contacts trigger the relay for flick wipe and jump them with a voltmeter set to the current scale. If nothing happens change the relay and try again.
Where is the relay on the BCM exactly and can it be changed and how?
To be honest, the BCM is perfectly coordinating the lights, rear wiper, washer jets etc so I don't like to think it's that either.
If this was mine, the BCM would now be on the bench, after probably lots of swearing during removal, with a view to locating the errant relay and its connection path.
In order to triple-check and fully check that Earths aren't the problem, is anybody able to explain all of the relevant fuses that need checked, we checked about 4 and they were all clean looking! And plus, isn't each earth going to also affect other systems if corroded/affected in any way?
if fault still there consider body computer faulty......... not worth repairing.................... find same spec... or higher as suggested a lot earlier in thread by bill i think?............dont worry about mileage discrepancies and if it fixes your car fit drive and move on
Replacing a relay in the body computer will be much easier and cheaper than sourcing and fitting a complete ECU/BCM/lockset.
