Asda snow socks £35
Asda snow socks £35
Essex/Suffolk border
My old snow socks still have some life left in them but I bought a set of michelin easy grips in Costco. They look like they will be easier to fit to my alloys as the tyre covering part is a 'rope net' with metal clips at each joint. The whole thing certainly has a bit more flexibility than the socks.
These asda socks are very similar to my original socks - except for the asda ones don't have an insert on the outside of the wheel (to maybe prevent the sock from wriggling too far over the tyre).
how much at costco?
What's the legal stance on using snow socks ?
There are strict laws on tyre tread and there has been much discussion about whether insurers need to be notified if winter tyres are fitted, and whether insurers are justified in increasing premiums.
There is a greater chance of being involved in a bump in snowy / icy conditions, so how do insurers view the use of snow socks if they are being used at the time of an accident ?
Tyres have a limited life, and there are laws regarding the minimum condition, but when is a snow sock deemed to be worn out ? I assume that their effectiveness will reduce as they wear, and if they are used in patchy snow then I would expect significant wear at 25 mph on tarmac.
I am not disputing whether snow socks work, but are they legal, does the insurer need to be informed (of their occasional use in suitable conditions), and would insurance be valid in the event of an accident (either on snow or on tarmac, at low speed in patchy snow) ?
But if winter tyres are in manufacture recomended size there is no issue.
With regards to if a sock is worn out, doesn't matter as its not a legal requirement anyway so will be no different to not using one surly?
i don't reckon insurer needs to be informed about socks because its a temporary thing, you don't have to ring them up if you are using a steel spare wheel on a car that came with a tin of goo.
you will only be using them when needed, if you was too keep them on any longer then i reckon a road traffic act will be broken
Will that count do you think for Chains?
Since Chains are again only temporary?
Ziggy
I'd have said they might be slightly different though, due to the liabilities of damage you can do to the road etc. Not sure though in all honesty.
IMO chains are pointless in the UK except for perhaps extreme highlands.
