Technical  arb bolt problem
rallycinq said:
Its a 'plug' one cos the thread goes right to the bottom.
Yep...at least from what I remember from when I last used a full set...
The taper tap is only really necessary IMO if youre doing long holes - most times you can get away with only using a 2nd tap.
right then.
tap'd the new threads and the bolts are in yay!!!!!!!!
unfortunatly both anti roll bar end brackets(to the lower arms)sheared there threaded studs on removal so ive ordered new ones from fiat.
over £40!!!!!!!!!
but got to be done and the balljoints were gubbed so at least its one less job fro the looming MOT
