Any beyond buying there making your own tools.
I hoard all sorts of rubbish. Old hose sections, battery caps, gudgeon pins, nut, bolts, tubes, old cam belts, old bushes, old bearings, etc. etc.
Need a clutch alignment tool. Make it. This is where copper tube or 1/2 inch socket drive extension, old bits of hose, electrical insulation tape ..... can make a perfectly good clutch plate centralisation tool.
Need to drift or press out an item. Then those old bearings, gudgeon pins can come to the rescue.
I liken the tool making / saving day option to that which Apollo 13 had. What have you got (rusty old rubbish) and what do you need? If you have nothing in the box then you can't make anything you need.
On a twin cam engine you need a camshaft lock to undo the cam nut. As a last resort if you have an old cam belt then you can "figure-of-eight" lock the cam pulleys together with an old cam belt and mole grips. Not ideal but it does work.
So I make a permanent habit of not discarding old items and put them to one side for potential use. This applies to not only car originated items but to everything in the house. I will strip old appliances for cables, internal wiring and spade connections, fuse blocks, etc. Furniture gets inspected and stripped for potential future problem solving solutions.
I think what we would ideally like is the "Star Trek" replicator. The nearest I can get is based on old bits and bobs and some ingenuity.
