alternatives to jubilie clips
Bushboy
Chris
Cheadle, Staffordshire
Come to a bit of a problem working on the car today. Ive taken off the standard fiat single use clips and have just been putting the car back together to find that a jubilie clip fouls the side of the gearbox when used on the inner CV boots, where the standard fiat thing doesnt :(
The Fiat clip is a no hoper at getting it back on and so what alternatives do I have to a jubilie clip that does exactly the same job but is flat instead...
Hope this makes sence anyway.
OP
OP
B
Bushboy
Chris
thought about a cable tie but i doubt I would be able to get it tight enough to do the job.
what do you mean by rotating it? The boot turns all the time so would watch every time the wheel turns. I cant really think of how i could rotate it to make it not catch :confused:
arc
this is where i stand
Manchester
meant to use metal cable ties on the boots, they come with the universal CV boot kits from frauds. i bought some off ebay to attach heat wrap to me exhaust. not sure where sells them in the real world.
OP
OP
B
Bushboy
Chris
ill go get a CV boot kit then from halfords.
Any idea on the rough price? Oh and what section will be it in? Halfrauds like to hide things in funny places.
jug
blessed are the apostates
Durham
never use a jubilee clip.
you can use cable ties, many cv boot kits come with them, and its fine for an MOT, but imo its not a good idea, i've seen them pop off too many times.
any motor factor will sell you a metal clip, usually called pinch rings, they cost 50p each, just ask. it helps if you take the old one to ensure you get the correct size. you dont need the special tool for tightening the clips, but they do make it easier.
Hellcat
zombie nation
on the A684
I've seen a kit for those metal crimp kits. Almost looks like a set of pliers and gets them nice and tight.
OP
OP
B
Bushboy
Chris
well just been to a motorfactors and they gave me some clips but im a little confused how to use them. there not like cable ties where u pull em through and they lock on the ridges... they said on the packet "metal ties for CV boot" so i assume they will do the job but how im supposed to put them on i dont know lol.
im going to go and have a guess.
Hellcat
zombie nation
on the A684
Do they have a hole to feed the other end of the tie through? If so they do work just like plastic cable ties.
OP
OP
B
Bushboy
Chris
Yeah pretty sure I need a tool as ive just tried in the only way I can work out they go on and whilst they are on and secure, they arent as tight as they should be. They close at 5 so cant get back tonight so may just nip to halfrauds and see what theyve got in a bit (although its not exactly close...) or wait untill tomorrow. or not do it atall as ill be booking the car into a garage asap to get the gbox done anyway and it will all have to come off again :p
Peterborough
that side CV boot is nearly new btw Chris, old one split when the garage I used to have a new clutch fitted didn't route the low pad warning wire out of the way and it wore through the boot... what an ass :(
