Y yamahoj New member Joined Apr 12, 2017 Messages 3 Points 1 Apr 13, 2017 #1 I have a Peugoet Expert 2.0 2003 (same as Scudo 1.9) My problem is that the Airbag indicator does not turn off when the engine been started. I wonder if someone have any suggestions what could be wrong.
V varesecrazy Patron member Parked in the garage Written 10+ guides Written a review Joined Apr 27, 2011 Messages 35,165 Points 7,886 Location Near the M4 Apr 13, 2017 #2 Red or yellow..? Ideally you want to read the error code..it will point towards the issue the body computer is seeing. Charlie
OP OP Y yamahoj New member Joined Apr 12, 2017 Messages 3 Points 1 Apr 14, 2017 #3 The color is yellow. Whatś doe's the difference between red or a yellow mean?
V varesecrazy Patron member Parked in the garage Written 10+ guides Written a review Joined Apr 27, 2011 Messages 35,165 Points 7,886 Location Near the M4 Apr 14, 2017 #4 yamahoj said: The color is yellow. Whatś doe's the difference between red or a yellow mean? Click to expand... Probably NOT the steering wheel airbag. As I said let us know your location.. Get the fault code read...attempt to clear it..and go from there. Air bag system faults are normally flagged constantly ..whether its an active or historic error. Charlie . Oxford Last edited: Apr 14, 2017
OP OP Y yamahoj New member Joined Apr 12, 2017 Messages 3 Points 1 Apr 14, 2017 #5 Thank's Ok I'll try to borrow a code reader and follow your instructions.
V varesecrazy Patron member Parked in the garage Written 10+ guides Written a review Joined Apr 27, 2011 Messages 35,165 Points 7,886 Location Near the M4 Apr 14, 2017 #6 yamahoj said: Thank's Ok I'll try to borrow a code reader and follow your instructions. Click to expand... it will need to communicate with the BODY computer.. not just the engine
