I have had a Fiat Scudo MY 2015 AdBlue130 Mutijet engine code RH02 in a workshop for 2 months. The vehicle had engine damage, and an identical RH02 engine from a donor vehicle was installed. My problem is that the workshop has not been able to start the vehicle for a month. The fuel pump has been changed, but there is still no fuel reaching the injectors. The workshop then used a hand pump and a self-made pre-feed pump, but the vehicle still won't start. The injectors are all functional; no fuel is leaking, and the compression lines to the injectors are also tight.
The workshop is at a loss, and my vehicle is without a solution.
Does anyone have any idea what the problem could be?
