Oakley28,
does the ABS warning come on:
1. After engine start, but before moving off with no further warnings, or
2. Does it come on after say 1 minute of driving the car with occasional further annoying "beep beep beep, Warning....failure" while you are going along?
If it is case 1. then in my experience of much-fettling with my ABS problem I reckon it could be a broken wire to one of the sensors or (hopefully) a dodgy connector to one of the sensors, so do as previously posted and disconnect each sensor in turn, cleaning it with electrical contact cleaner and connecting firmly back together.
If it is case 2. then try disconnecting each sensor in turn, driving around and seeing what warnings come up. If during this procedure of trial and error you find you have only the warning at start up but no more occasional warnings when you drive along then this (disconnected) sensor is the wheel where the problem lies. You then have to guess whether it is a sensor or the wheel bearing which is the problem. If the wheel bearing seems fine then the obvious choice would be to change the sensor first as this is much easier (and cheaper).
Hope this helps. All the best,
RRP
p.s. Sensor was about £27 from one FIAT dealer, but another wanted £54 ! This took me about 1 hour to replace.
Wheel bearing was about £40 from ebay and took me half a day to replace with the help of a man with a 10 tonne press.
RRP
