My 2004 panda 1.1 active manual 35 K on the clock, does the same in low gears as I come of the accelerator. I have tried the injector cleaners twice but it didn't help. Please let us know if you got your problem fixed. Thanks
It is not clear to me exactly what 'system decompression' and 'configuration test' means! I assume the former means that air was bled/purged from the system
In that case, I'm assuming that the 'test configuration' is exactly what varesecrazy (Charlie) did when he visited my father and connected up his version of MES, but unfortunately this made little difference.Correct, configuration is the ECU relearning the gearbox / clutch (wear) parameters, not a software update. All can be done with multiECUscan software also if needed in the future![]()
So it seems likely that the 'system decompression' (purge?) was what really fixed the problem.
That sounds reasonable... Charlie was unable to undertake this procedure as they were unable to check the fluid level beforehand (and had no fresh fluid to top the system up with).Yep, it would have removed any air from the system which was probably causing the clutch bouncing.
But how did the air get in?
Actually, the fluid was found by the dealer to be at the maximum level. It's a mystery!Possibly low fluid, or if its sat for an extremely long period of time and the system lost all pressure, then when repressurised air may have been reintroduced, as the reservoir isn't an air tight one if that makes sense?
I should really give proper credit to the dealer... Eden Fiat, Basingstoke.
Maybe.RE-READING THIS.. IT REMAINS A MYSTERY , AS "LORE" HAS IT THAT THE SYSTEMS ARE not filled FROM NEW, JUST ABOVE THE MIN-LINE APPEARS THE NORM..,
:idea: maybe this level was taken BEFORE purging the air..??![]()
Hi David. It's good that you've found a convenient work-around, but I really do hope your visit to Basingstoke brings about a full and permanent repair.Hi, just been updating on this thread. I'm the one from the North East. Still having trouble, but I find that if I keep the handbrake on a little while accelerating ,the jerking disappears. i.e. putting some load on the engine as I set off seems to cure it. Hoping to do a tour of England and visit places I've never been to , and call into the afore mentioned Basingstoke Fiat dealer .Kill two birds with one stone, so to speak.
To bring this thread to a conclusion, I am pleased to say that my father's car is now running smoothly again, following some apparently minor attention at his local Fiat dealer a couple of weeks ago.
He visited this dealer to obtain some of the specified fluid for the gearbox/clutch system and, while there, decided to ask for advice. He was told that the solution was likely to be simple and agreed to let them take a look a few days later. The fluid level was found to be correct (apparently it is only possible to check this properly from underneath the car, with the vehicle well up in the air) but - as described on the invoice - the dealer then undertook a 'system decompression' and also carried out an ECU 'configuration test' which has resulted in the clutch now operating smoothly and able to hold the car on an incline.
It is not clear to me exactly what 'system decompression' and 'configuration test' means! I assume the former means that air was bled/purged from the system and the latter could mean that the ECU software was upgraded... can anyone confirm this?
Including a 30 minute test drive carried out by the mechanic, the total bill was only 50 something pounds, so it seems very reasonable. I would therefore suggest that anybody having similar clutch engagement problems should consult their local Fiat dealer!
