Technical 312PXL2A P6B VERSION 1.3 DIESEL 4x4 FRONT COIL SPRING
Manchester
Dear All,
I have an issue with my car, the front is much lower compared with the back.
Someone told me that probably the previous owner put the normal fiat panda springs in the 4x4.
But I called fiat that gave me this oem 51939621, I check in hte after market and all the oem products in the specification field states " color codes x2 white x2 yellow"
first , what is the color code?
Second, I already have springs with x2 white x2 yellow dots. (please see the pictures).
I do not what to buy something that will not fix the issue. (are other oem number could be compatible with 51939621,?? i am asking because if I do not use the oem number search in the aftermarket internet sites, like autodoc, for my model it show me items that are compatible with more than one oem number)
third : can you suggest which brand do you prefer for springs and shock absorbers?
I heard that bilstein is more rigid and monroe is good and not too ridig.
thank you in advance
