Hi, I have a 2010 Fiat Doblo Eleganza, driving the other day and I put the passenger window down half way by mistake. When I pressed the up button it just clicked, I thought If Iput it down fully it may go back up (it did not). Now I have the passenger window fully down pressing the buttons on the passenger door you can hear the down button going but just a click for the up button. The same on the drivers buttons. I ordered a new switch from onlinecarparts did not realise they were in Germany and the warehouse in Poland, finally got it today replaced the drivers side switch and the same makes a noise when pressing down and a click when you press up. All of the other windows work fine go up and down no problem. Cannot find the fuse location for the passenger window switch (but then again that would stop it trying to kick in when pressing the down button). I cannot put the window back up as there is nothing to grab hold of. Is there any way to manually turn a winder or something to get the window back up? Does anyone know which wire to check for in the door loom for breakage for the up part of the passenger window? Any other suggestions would be grateful as at the moment I cannot use it with the window down, even if anyone knows how to get the window back up would be great.
Cheers in advance.
Quick update now when I press the button I get a click and nothing on the opposite possibility it may be regulator or motor? any way of testing?
Cheers in advance.
