I found this Italian version for Grande Punto. Hope it helps.
Finding an ECU isn't as easy as you may think as the part number is different for the Doblo than any other 1.4 8v, No, didn't touch anything around the steering column, was all in the engine bay and have searched everywhere for a blown fuse etc but, having traced the power it points to the ECU not working sadlyShould be easy to find one. Around me I see there are plenty.
Very weird though how yours stopped working. Did you do any work around the steering column? Immo has a little wire connected to the key contact, it works like an antenna used to read the code stored on key. The immo light remains on when you try to start the engine, right? That is the problem and yes, that is why the fuel pump doesn't engage. Really strange. I'm curious about what happened there, what's causing the issue. Without knowing, you risk not being able to fix it. Like putting a virginized ECU, if the code from the key cannot be read you'll be in exactly the same spot.
