Technical 2009 fiat panda miss fire after changing spark plugs
Deemoandy
Cornwall
Please advise.. 2009 fiat panda 1.1.. just changed the thermostat so removed the coil pack bracket. Then replaced the spark plugs.. whilst changing these. I disturbed the first (left side) yellow connector by the spark plug.. after reassemble and starting I now have a miss fire.. could it be the yellow connector or have I disturbed the coil packs / HT leads? Any advise would be appreciated
Are the plug leads on in the correct order and are they firmly pushed down onto the plugs. Try that to start with. It will be something simple as a bad connection as the engine was running fine (or was it before you changed the thermostat)
Yeah was running great.. do you know what the yellow connections are by the plugs.. well I think they are yellow as I’m colour blind .. also how do I find the information on the correct order of plugs .. thanks in advance
I take by misfire your taking about a regular pop sound of a cylinder not firing
Start by working out which cylinder is not firing
This is my euro 5 which has slightly different layout
Take each lead off the coil one at a time and start the car
The one that makes no difference is the one in that misfiring
Fingers crossed is just a lead on top of a plug that's not seated correctly
