Hi all,
I hope I can find some help on here as I'm at my wits end with this car.
As the title says, I have a 2008 Fiat Panda 1.1 Active.
A few months back I hit a rock in the road and engine mounting broke which snapped the cambelt.
Having mountings repaired, cambelt and pully replaced, timing set correctly etc, the engine turns but there is no power to the injectors.
I have taken it to a local mechanic who had ran the OBD, came up with 9 errors, 6 of which he cleared though 3 keep coming back:
PO202 - Injector circuit open
PO351 - Coil circuit open
PO352 - Coil circuit open
He keeps referring to the key code being an issue, but as far as I understand, that if that is the case then the ignition wouldn't work either, I suspect a wiring issue as no signal is being sent to the Injectors or the Coil from the ECU.
Please keep in mind that I am a far throw from knowing the inner working of the car, so please use small words
Any advice in this regard will be greatly appreciated.
TIA
TIA
