Technical '06 Panda crank sensor issue.....
First yes no fault codes secondly i kept everything as default only changed the baud rate for the pairing to work nothing else
I did some digging and readed somewhere that the immobilizer is able to cut both coils and injectors which means that it might be the culprit based on the 3 flashes after a failed startup attempt?
Yeah i went there with the cable and refused to work didn't get this latency too high error it just works partially like i can enter but can't read faults or live data stream using the cable
But with the mini elm327 after successful connection it worked like a charm
Yes the immobilizer will cut the injectors and coil
But I thought you had no errors in the BCM or ECU without cranking
The actuator test should be working
As for the ECU nowadays it's rarely ever reading the CPS and still with the fault available it reads RPM normally
But what gets me confused shouldn't the car turn on when i crank with no DTC's including the 9022 even if the failure is available ?
Like at first when it started acting up sometimes when i clear the fault codes the car would start immediately after it goes out and sometimes it did fire back up even without clearing any faults
Well now there is a crank signal no DTC except the 9022 but the car still refuses to fire up
I'm not sure if more faults showed up with all the ignition on and off trying the dongles but that's what happened the last time before we moved from Ancel x5 to multiecuscan
Let go back a step
It doesn't prove anything, but it was one test early that didn't give the expected result
Multimeter on the engine block and the ECU while cranking was 0.8 volts, is this still the case, we have cleaned up the earth's since then
The car started last time directly after unplugging the camshafts sensor is this still unplugged
No i plugged it back in after unplugging it failed to do any change want me to remove it again?
It's giving 0 degrees while ignition on and 10.4 degrees while cranking
