Hello all,
I have an issue with my 2009 panda where it suddenly loses power and jolts/judders at higher revs - anytime I try to accelerate quickly / go steeply uphill / have more weight in the car it is likely to happen as the revs get higher. (I can't say what sort of range as the car doesn't have a rev counter :-/ )
It is quite sudden and will sort itself out once the revs drop, either by slowing down or shifting up a gear (neither of which is a very good solution if trying to accelerate or go uphill, and frankly terrifying if on a DC or motorway!) and quite often I find myself gradually decelerating and completely unable to pick any speed back up.
When it happens the engine warning light will come on solidly just for a couple of seconds, though in addition to this it has recently begun to constantly flash.
I have taken it to three garages now, none of whom have been able to give me a definitive diagnosis. The most recent mechanic who looked at it finally got a fault code reading for the crank shaft sensor, but he was very unsure if replacing the sensor would make any difference.
Having read a few posts from others here there seems to be a few people having similar issues who have mentioned a wiring loom. I know embarrassingly little about cars, so that is meaningless to me!
Could anyone suggest what might be causing my problem and if so, how do I best go about fixing it? Will replacing the crank shaft sensor help, or is it the wiring loom that needs fiddling with, or something else entirely?
Thank you all in advance for any and all advice!
