Technical '06 Panda crank sensor issue.....
Just started messing around with it again found that the error code is 10 that's why the driver is failing
Finally thanks to GitHub managed to get it to work BUT scan for hardware won't work and putting it manually and testing results in a timeout as in the picture any idea about this one?
Does it need a driver aswell? Because i remember using it on my android with torque pro obd and it was simply pair and run never tried it with windows and unfortunately mes is not available on Android someone needs to address this issue though.
Correct just paired
AlphaOBD is on Android if I remember correctly
Free version does not allow you do any bidirectional just read and clear codes
I maybe wrong it's been years since I used either
This was my solution if someone had the same issue
It gave me after selecting elm 327 and testing manually that it should connect properly hopefully the weather is decent to be able to work on it
Lets get all the errors cleared and the throttle relearn done
Be nice to see the throttle, ECU and scan tool all talking
The ECU should step the throttle plate to its stops and come back with a pass or done
Saw how it performs on YouTube gonna put an eye on the throttle during the relearn to be sure it's being done physically as it should
Managed to connect to the ECU went iaw5nf injection i didn't get the full details of it no idea why so i continued went and checked for the actuation of the injection and coils they either fail or say success without activating and it takes so long without the system reading the DTC available it keeps saying reading fault codes
That's what I'm getting abnormal right?
Ok so miraculously the Bluetooth mini worked after setting it up manually and trying all baud rates anyway same as ancel 1 and 2 coils activate whereas 3 and 4 immediately fail as you can see in the video and in the pictures these are my data about the car and what is available didn't see throttle relearn anywhere
  • VID_20240408_112139.mp4
    61 MB
Sorry for the inversed video but as you can hear in the video the relay ticking engaging and disengaging but no spark
And forgot to mention that i went again and actuated all 4 injectors no audible ticking from them only the relay, the same as you heard from the video
Am I reading it correctly
MultiECUscan is saying there's no errors present in the ECU module
Did you set the Latency Timer to 1 and the buffers to minimum on the serial port driver?
Looking at the results it looks like I have made a mistake somewhere or missed something
I very much doubt the coil and injector have blown, especially since they both intermittently work
