Technical '06 Panda crank sensor issue.....
Hi there I'm back online after the ISP strike and would like to ask what to check next because i couldn't make it with the multiecuscan probably tomorrow or after tomorrow
My question is what can block the ecu from sending the signal to the injectors and coil packs? Because after what we tested and the fault shown he's reading the CPS sensor but is not getting the permission to open the injectors and coil packs
Some errors present will stop the ECU to protect the engine
We are trying to control the injectors and ignition coils manually
We have power going to both
The ECU activates the relay for both
We have no ground side switching for the injectors or coils at the ECU
I can not believe the drivers inside the ECU to both the injectors and coils are both blown
We have not tested the connection from the injectors and coils to the ECU as I would doubt all 6 wires were faulty
We're were going to get MES up and running so we can clear the throttle relearn error and see bidirectional control via the ECU
It should not be that difficult to get the USB ELM327 working it will require the correct drivers installing
I'm working on it my sister's laptop detected the Bluetooth yesterday but i was too busy to have time to try the MES anyway tomorrow she's with me all day we'll download and run MES and do the relearn as for the faulty stuff it's pretty impossible because when the car decides to run it runs perfectly normal and smoothly too so there's definitely nothing wrong with the wiring the issue is with the ECU not sending the signal to the coils and injectors but the why? I don't know
Hello there once more unfortunately nothing worked i tried both USB and Bluetooth and could not make multiecuscan to connect to them and in this picture as you can see the driver won't work and i tried another one too to no avail and i tried letting windows automatically download the required one and it still doesn't work and MES won't detect any, i managed to land a manual connection but unfortunately the 250ms latency test terminated and refused the connection so any other plans?
I have tried with literally 4 laptops and none worked on both dongles
You need the prolific driver
You can download it directly from there website
Window will not automatically download the correct driver
I know you sent the file and i tried it and here's what i got, saw a YouTube video aswell and still have the same issue and the windows default driver gives me a warning that the driver is outdated since 2012 as i said tried all 3 of the drivers on all 4 laptops and none of them worked
And forgot to mention that the elm 327 is a mini and when i attempt connecting it says that it does not support Bluetooth v1.3
Do you think this one will work? Do i order it? Or is it better as Bluetooth?
That's so nearly there
You have the usb installed
You just need to install the correct driver from pack 4 I believe
I know but I can't find the compatible driver with it if you have any idea about it do tell I'll immediately go and check
So if this one work I'll buy it it's just 5.6$ nothing major after the 300$ i have payed so far without the issue being fixed so if it gets your approval I'll get it and if there's a better one tell me which one if you can
Sorry to hear you still having problems
I use a cheap mini bluetooth fine
And a usb KKL cable fine
USB is the one we ideally want running, mainly incase we need to do a proxi in the future, I doubt it will be needed
Remove the tick from the show compatible hardware
Select: Prolific driver version 3.3.2.102
use disc or something like that and navigate to directory where you downloaded the file
once paired the cheap Bluetooth elm 327 normally work fine
the only time I have had problems is when I accidentally leave it paired to a different phone by accident
iPhone will not work with most of the Bluetooth ELM327, it's none standard, I have never managed it
Should work via Wi-fi but I have never tried it
By cheap Bluetooth elm 327 you mean the mini too? Because mine is a mini and i can't manage it to work, i get that it does not support Bluetooth v1.3
Does it need a driver aswell? Because i remember using it on my android with torque pro obd and it was simply pair and run never tried it with windows and unfortunately mes is not available on Android someone needs to address this issue though.
