Technical '06 Panda crank sensor issue.....
Clear all the codes
Leave the ignition off for 20 seconds
Switch the ignition on but don't try and crank the car
What codes are present if any just the numbers
Try it a few times
If no codes comes up we know 95% it's a power, ground issue
Any idea what to look for?
We are looking for no codes to pop up with just switching the ignition on and off a few times
We don't need to crank the car at this point
Also keep an eye on the oil and battery warning lights
Also is the engine check still light dim
Ok so now all faults off (the only one is the phonic relearn that i cleared) removed obd2 connector and key from the ignition and waited more than 20 seconds this is the opening after doing the procedure only ignition on after clearing all faults
  • VID_20240319_121538.mp4
    24.4 MB
I don't remember if i did mention that but when i removed the camshaft sensor the last time you asked i got the excess water temperature warning when i opened the ignition i think i did mention this thing
All the light look correct to me
Oil and battery are coming on together
Immobilizer isn't doing it's extra blink
The engine check light does not look dim
Try it a few times
Then read the codes
Don't crank the car
No need to post images or videos unless something is out of place
Normal with a flat battery for the gauges to misbehave
I know it happened while driving to,
Try it a few times
Then read the codes
Don't crank the car
Gonna try again in a few but the check engine light is in fact slightly dimmer than it should all the time I'll send you a video to explain what i mean. Normally it's a little dimmer then when i give order through the scan tool to light the check engine you'll notice it becoming like 15% brighter than on ignition in the on position
Alright so after the video i didn't diagnose closed the ignition and left the car till now i opened ignition checked and found
P1300 Phonic Wheel Learn ECU
only DTC cleared it and still didn't try to crank
ECU: P1300 Phonic Wheel Learn
TCM: Clear
ABS: Clear
EPS: Clear
SRS: Clear
BCM: Clear
Instrument panel: Clear
only DTC cleared it and still didn't try to crank closed and reopened ignition 2 times got the same again and again
Great
It can't do relearn until the engines running so that's normal, I guess you have erased the adeptive memory on your scanner
So between the ECU and the body computer everything is communicating properly when there is no load, the key code is being transferred properly
So this means it's failing under load?
But if that's the case why's the car crashing while driving?
There is no power surge from the starter while driving it shouldn't fail
No there are far more amps in the circuits when it's running
Radio, blowers, alternator and so on
Also if it's a loose wire you vibration, road bumps
Ok so while I'm driving radio is off and the blower is off now there is something i noticed at first i noticed when the issue began the car mainly failed on right corners mostly or more preferably only
Now the TCM used to return always an alternator fault do you think it's its fault
These are all 3 terminals
