Technical '06 Panda crank sensor issue.....
Where does the middle one connect to on the body work under the battery try maybe
What's under the bodge on the right one, wrapped in electrical tape
We are not helping ourselves here
To carry a few amps its not too critical
But to carry over a hundred Amps every has to be clean and in good order
I can see the battery terminal has a dark layer of non conductive oxides
The earth posts themselves don't look like they have be cleaned
Looks like there's been a problem here in the past, two posts appear to have a second nut on the top
Get a
Or similarly and clean everything up first
It goes in a half turn next to the chassis down under the battery behind the headlight and it's shown where it's fixed in the 2nd picture
Get a
P200 sounds good? Or something softer like 300 or more?
Yep this is the one fixed by 13mm bolt will start there than go up to the battery
Turns out this was the one fixed with the braided ground wire to the gearbox and was cleaned but went ahead and cleaned it thoroughly again so on the second picture that wasn't clearly visible you can say that it's now checked
Cleaning those aswell although all contact points are clean
And that's after cleaning thoroughly do you think i should apply terminal protection grease before assembling?
No i added them extra for the external ground to the engine they're useless but you didn't tell me want me to put terminal protection grease before assembling?
