RDM1
Established member
I couldn't hear a tick when activating them but i hear fuel flowing in the rail
Yes the fuel pump has to activate as well as it uses the same relayIt might be the fuel pump I'm not sure
With your lampWhat about the lamp tryout?
Not if you can hear the ECU clickBut now is it possible for the bcm to cut off the injectors and coils?
Assuming the scan tool is working correctlyYea whenever i actuate a coil or an injector i hear the ECU tick. What might be the cause of that if the components aren't activating but the ECU is?
ECU driver, short a component or wiring
You could try disconnecting both coils and trying the injector test again incase there is a short in one of the coil primaries
