Technical '06 Panda crank sensor issue.....
How many volt is there? I think i can manage a bulb to test with it I don't think I have 6v but 3 there is and 12 too
Ok and tried with the multimeter i got 0.135v and 0.55v while cranking between negative and the yellow/brown wire on both plugs the higher value is for the rear coil plug
Values are not accurate there's no power at all on them even tried on the DC too
Right back in the house
It has to be a LED a bulb will short circuit the coil and stop it firing anyway
Not the results I was expecting
0.135v and 0.55v was expecting no change while cranking
Have to have a think where to go next
Welcome back but what do you mean with what you said here?
Because if you mean putting on a 3v bulb i doubt it'll light at all even with the initial 1.2v initial spike
Anyway my question is can a faulty bcm cause the ECU to cut the signal?
On the ECU signal it's almost null or something about 4mv it's always like that even after the 2 seconds at first but when cranking it goes up
But now thinking about it when the car decides to fire it runs normally and no spark on all 4 spark plugs with the other wire giving a normal voltage on the other wire (coil plugs) means that the ECU is cutting the signal himself
Now as i previously mentioned i suspect the BCM to be acting up because last time the car ran after i cleared the BCM faults while it was running, the engine immediately went out
So this is a 12v lamp i had and each video is for a coil
positive battery terminal and the ECU signal wires
  • VID_20240331_110734.mp4
    23.3 MB
  • VID_20240331_110907.mp4
    21.3 MB
